A full list of all the markdown shortcuts available to you in your docs.
If you like using Markdown for fast on-the-go formatting, you're in luck. You can use any of the following Markdown shortcuts in the canvas of your doc.
📣 Superhuman Docs now supports pasting of Markdown text into docs. You can copy your Markdown text, paste it into the page of your doc, and watch as the text is automatically formatted. If you need to, you can still choose to paste the text as either plain text or as the original Markdown text. Learn more here.
Inline
Bold: **text** or __text__
Italic: *text* or _text_
Strikethrough: ~text~
Emoji: :emoji name:
Reference: @
Paragraph
Large header: # space
Medium header: ## space
Small header: ### space
X-small header: #### space
Numbered list: 1. space
Bulleted list: * space
Checklist: [ ] space
Block quote: > space
Pull quote: " space
Code block: ```
📣 Tip: You can find the most up-to-date list of supported Markdown shortcuts by clicking on Insert in the upper right corner of your doc, typing Markdown into the search bar, and selecting Markdown (under Keyboard shortcuts).
