Build embeds for Superhuman Docs
For our third-party partners: Find best practices for building embeds in Superhuman Docs.
Embeds in Superhuman Docs allow users to integrate external content into their docs, providing a unified workspace for teams to collaborate without switching between tools. With these embeds, users can bring their favorite tools and data sources—like Google Sheets, Miro boards, Figma designs, or dashboards from analytics platforms—directly into the context of their Superhuman doc. Rich embeds take things to the next step, allowing users to view, interact, edit, and update external content in real time. This simplifies information sharing and keeps teams aligned without the friction of navigating across multiple platforms. To build an optimal rich embed of your tool for Superhuman Docs, check out the information below.
📣 Please note that this article is not intended for our general customer base, but rather for our third-party developer partners. The information here aims to guide you in building an embed that will optimize the use of your tool in Docs.
Available embed methods
When building an embed for Superhuman Docs, it may be helpful to consider how customers are embedding third-party content in their docs. There are two ways customers can access embeds within the platform.
  • Full-page embed: Turn a page in a doc into a partner embed.
  • Canvas embed: Pasting a URL directly into a Superhuman doc and selecting Embed as the display option, or using the backslash ( / ) command in the document to bring up a flyout and select the tool to embed.
Technical considerations
Superhuman Docs uses the 3rd party service Iframely to handle embeds. Many popular apps and websites are already supported, and you can use their site to check if a URL already supports embedding. There’s also an in-product compatibility mode that bypasses Iframely and directly shows the embed.
Sandbox restrictions
The iframe containing the embed is sandboxed by default and has limited permissions. These restrictions default to:
  • Prevent access to cookies and local storage.
  • Disable form submissions.
  • Block script execution.
  • Restrict popup windows.
  • Prevent navigation of the top-level browsing context.
If you need access to additional iframe sandbox permissions, please contact support.
Sizing
Your embed should implement responsive sizing to ensure optimal display across different screen sizes. We recommend using percentage-based widths and setting an appropriate fixed height or aspect ratio.
URL
The URL must be secure (i.e. begin with https://) and must not prevent being loaded in an iframe via the X-Frame-Options or Content-Security-Policy headers.
Editable embeds
Editable embeds allow users to interact with and make changes to content directly within a doc. Partners like Zoom and Miro enable edit functionality so users can stay in their workflow, eliminating the need to switch between platforms. This creates a unified experience and maximizes the value of the embed. Consider making your embed editable for optimal customer experience, and check out a few examples from other partners below for inspiration.
ℹ️ Further considerations:
  • For details about the
  • For info on how embeds work with Packs, read here.
  • To learn more about how customers work with embeds in Superhuman Docs, read here.
Embed examples
The following are some examples of highly successful partner embeds. To see the embeds in action, we recommend adding them to a doc and playing around first-hand.
Miro
Brainstorming sessions become more interactive with editable Miro boards embedded in Superhuman Docs, allowing participants to add notes, shapes, or comments directly in Docs.
Zoom Whiteboard
Teams can collaborate on a Zoom Whiteboard embedded in Superhuman Docs, adding sticky notes, annotations, or sketches during a planning session, with all updates syncing back to Zoom.
Want to partner with Superhuman? Apply to be a partner here.
