Supercharge your doc with Zoom to seamlessly provision and manage users and their meetings.
There are a few great ways to connect Superhuman Docs and Zoom. If you'd like to use Zoom admin information in your docs, continue reading. If you'd like to use the Superhuman Docs app for Zoom natively in Zoom meetings, please follow these instructions instead.
Requirements
In order to use the ZoomAdmin Pack you must be provisioned in Zoom as an account admin with permission to manage users, meetings, and recordings. You can learn more about Zoom account roles here.
Install and connect to the Pack
To start using the ZoomAdmin Pack, you first need to install it in your doc. You can do so by following these steps:
  1. On any blank line in your doc’s canvas, type a forward slash, followed by “ZoomAdmin” (e.g. /ZoomAdmin )
  2. From the drop-down menu, select ZoomAdmin (under the More Packs header)
  3. Then click the Add to doc button in the upper right.
  4. From the right-hand panel, select the building block you want to add to your doc (such as a Users sync table, or a Create user button). Click and drag the selected item onto the canvas of your doc.
  5. You will then be prompted to connect to your Zoom account in order to access that data. Follow the prompts to connect your account. If this is your first time connecting to the ZoomAdmin Pack, you'll be prompted to sign in to your Zoom account.
Example use cases
The ZoomAdmin pack supports synchronizing information in your doc about Zoom Users and their Recordings. Additionally, you can schedule meetings for users via a button or automation. Check out some examples below:
Synchronizing Users or Recordings
As a Zoom admin, you can create a new table that synchronizes information about all users in your Zoom account:
  1. On a new line on the page, type /zoomadmin and click ZoomAdmin under the heading Pack Tables.
  2. Select the type of data you’d like to sync - either Users or Recordings.
  3. Click on Choose what to sync and customize your sync settings. You can customize the sync policies (frequency and size limit) and for Recordings you can specify the date range.
  4. Finally, click on Sync now to kick things off.
Creating a meeting on behalf of a User via a button
To schedule a meeting on behalf of a user using a button, take the following steps:
  1. On a new line on the page, type /button and select New button.
  2. Under Action select ZoomAdmin → CreateMeeting.
  3. Pick the account to use for this action. If you've allowed shared accounts to take actions, you'll see shared accounts here. If you've opted to require each doc user to add their own account, you can use "User's Private Account." To add a new account, select "Set up another account".
  4. Set the meeting topic and optional fields for start, end, agenda, and password.
  5. Lastly pick the user that you want to schedule the meeting for. You can search via. their email address. Alternatively if you’ve sync’d in the Users table you can use a value from User Id column.
Advanced Scenarios
Advanced scenarios for User management are also possible using button and automation actions CreateUser and DeleteUser. See the formulas ZoomAdmin::CreateUser and ZoomAdmin::DeleteUser for more details.
How do I uninstall the Zoom Admin pack?
There are several ways to uninstall the ZoomAdmin Pack from Superhuman Docs, including via your Docs account settings and from within the doc itself:
Via your Docs account settings
This removes the specific ZoomAdmin credential from all Superhuman docs.
  1. Navigate to https://docs.superhuman.com/account.
  2. Scroll down to the Accounts connected to Packs section
  3. Select ZoomAdmin and expand the account you would like to remove.
  4. Click on Remove this account. This will remove the ZoomAdmin pack from all docs.
Via the in-doc Packs menu
The Zoom Admin Pack can also be removed from a specific doc by navigating to the ZoomAdmin Pack settings.
  1. Click the Insert & Explore button in the upper-right corner of the doc
  2. Enter ZoomAdmin in the search box and choose the ZoomAdmin Pack from the options
  3. Click on the vertical dot menu, and select Remove Pack from this doc
How can I get support with using the Zoom Admin pack?
Superhuman Docs has three main support channels. Feel free to contact us if you have questions!
