Star docs of personal importance to save them to the Starred docs section of your doc list.
Not all Superhuman docs are used in the same way. You'll inevitably have a few that you use every week, and some that you'll only use once. This is where starred docs can help you stay organized.
Starring docs is a great way to mark docs of personal importance. After you star a doc, it will live in a section on your doc list called Starred docs - conveniently found in the left panel of your workspace home. All starred docs, even from multiple different workspaces, will live in this section.
Starring docs only saves them to your personal Starred docs. It doesn’t affect the view for others in your workspace. If you want to shortcut docs not just for yourself but also for others in your team or workspace, you’ll use pinning instead.
Add to your Starred docs
To star a doc, hover over its name in the doc list and click the star icon. Alternatively, you can star a doc from within the doc itself. Hover over the doc title in the upper left corner, and click on the star.
Once you star a doc, you can access it quickly from the Starred docs tab of your doc list.
And, as your doc needs change, simply click the star again to un-star the doc and remove it from your Starred docs
When should I star a doc and when should I pin it?
Starring docs is best for docs of personal importance. Starred docs appear in your Starred docs, but they aren’t starred for anyone else in your workspace. For instance, you may want to star your personal to-do list doc or any docs you use on a daily basis.
Pinning is recommended when you want to flag or shortcut a doc for everyone in your workspace or folder. For instance, you likely want to pin your company wiki doc to your workspace. And you may want to pin your team task tracker doc to your team’s folder.
Can I star docs for everyone?
Starring docs only applies to your own view and your own Starred docs. To pin docs (or templates) to your workspace or folder, refer to this article.
