Once you've connected to the Docs MCP, learn how to get started with best practices, examples, and more
The Superhuman Docs MCP (Model Context Protocol) is a connection layer that enables AI tools - like Cursor, Claude, etc. - to read and write to your docs using plain-language prompts. Instead of clicking through the Docs UI, you describe what you want in a chat window, and the AI carries it out directly in your doc. Think of it as giving an AI assistant the same access to your Docs workspace that you have, and letting it act on your behalf based on your instructions.
Coda is now Superhuman Docs, which means we've renamed our MCP. But if you've already connected to the Coda MCP, your existing connections will continue to work. Learn more in the FAQs below.
Haven't connected to the Docs MCP yet? Get started with this article.
Superhuman Docs MCP tools
- Creating, deleting, and searching docs
- Creating, deleting, updating, and reading pages - with access to a variety of building blocks including callouts, codeblocks, grids, and more
- Creating tables, adding and modifying rows, adding and modifying columns, configuring views, and deleting table content
- Configuring views, including detail layouts, filters, conditional formatting, and more
- Creating charts
- Writing and executing formulas
- Creating and triggering controls and buttons
- Resolving and reopening comment threads
- Building and editing AI blocks and columns
- and more being added weekly!
Best practices
Providing context
| Best Practice | Details |
| Provide the Superhuman Docs URL |
When you want to work with a specific doc, page, table, or row— share the URL directly as a part of your prompt. The agent will use url_decode to extract the IDs it needs. This is more reliable than describing what you're looking for and forcing the agent to search for it, which uses many more tokens. |
Use screenshots and files for ingesting external data |
When data lives outside Docs (Amazon orders, emails, PDFs), take a screenshot or export to CSV/markdown. The LLM can parse it, then use Docs MCP to add it to your docs. This is great for one-time imports. |
Chaining AI tools and capabilities to pass in context |
Different tools offer different capabilities:
If you have existing subscriptions you can leverage across these tools, you can chain them and pass context between them using Markdown.
Example: if you’re working with Superhuman Docs MCP in Cursor but need to parse a PDF, you can start in ChatGPT to convert your PDF → Markdown and then provide the Markdown file to Cursor to turn it into a doc.
Accuracy and efficiency
Turn off unnecessary MCPs |
It’s common to use many MCPs in your environment. For example, you may have Superhuman Docs, Atlassian, and Figma MCPs setup in your AI tool. However, the more MCPs and tools you make available to your agent, the less context it will have to pick from, and the less accurate it will be at performing tasks.
As a result, it is strongly advised to enable only the MCPs you need at that moment. You can always turn them back on when you need them.
Use local CSV and MD files for very large datasets |
When working with very large amounts of data (multiple large pages, huge tables), use markdown and CSV files to store intermediate work locally with Cursor, Codex or Claude Code.
For example, if you’re analyzing a Superhuman Docs table with 1000s of cells, store your analysis locally in a CSV or Markdown file while you are iterating. Once you are ready, you can upload it to Docs.
Tip: Sometimes, it is faster and cheaper to upload using Superhuman Docs' native Markdown and CSV importers rather than using MCP at this stage, as it saves AI tokens and works faster for deterministic imports.
Be selective with content to include |
The ReadPage tool supports a param called ContentTypesToInclude, which can be helpful for loading different amounts of context.
• Just exploring structure? → ["tables"]
• Need to edit content? → ["pageContentRich"]
• Just reading for context? → ["pageContentMarkdown"]
Requesting everything increases response time and token usage. So you can prompt the agent with something like “Read tables on this page” or “Read comments on this page” and it will automatically select the right options. Additionally, you can specify which columns or rows you’d like to use when Reading large tables.
Prompting
Describe the end result, not the steps |
"I want a meeting notes page with sections for attendees, agenda, action items, and decisions" works better than step-by-step instructions about which tools to call.
Describe what you’re looking for with precise boundaries and good details. Then let the agent figure out how to build it.
Tell it your goal, not just the task |
"I'm preparing for a board meeting next week" gives context that helps the agent make better decisions about structure, formatting, and what to include. |
Specify the scope and boundaries |
"Only update the Marketing section, don't touch Engineering" prevents unintended changes. Being explicit about boundaries helps avoid surprises. Similarly, you can tell your agent to only look at a specific page, doc, table or row. |
Provide examples when adding data |
"Add 5 tasks like: 'Review Q3 metrics - Due Friday - Assigned to Sarah'" gives the agent a pattern to follow. One good example is worth a paragraph of explanation. |
Name things clearly in prompts |
Use the actual names of your pages, tables, and columns so the agent can find them easily. "Update the Projects table" is better than "update that table I made last week".
See the related “Provide the Superhuman Docs URL” tip above.
Be specific about what you want changed |
Instead of "update my doc", say "add a row to the Projects table with name 'Q4 Launch' and status 'In Progress'".
The more specific you are, the fewer back-and-forth clarifications you'll need. You can use URLs to tell the agent what to look at, and you can reference specific pages, tables and rows. See the “Provide the Superhuman Docs URL” tip above.
Reference existing content as examples |
"Make the new page look like my 'Weekly Standup Template'" or "Use the same columns as my Tasks table" helps the agent match your existing style and structure.
You can also look at the “Personalize with rules files that read Superhuman Docs” tip below for a more structured approach. Note: we are currently improving how the MCP works with templates so this will get smoother over time.
Workflow
Request a preview on big changes |
"What would this look like?" or "Summarize what you're about to do" before executing.
Especially useful for restructuring, bulk updates, or anything you can't easily undo.
Ask questions before making large changes |
"What tables are in this doc?" or "Show me the structure of this page" before jumping to edits. This helps you understand what you're working with and catch potential issues early. |
Personalize with rules files that read Superhuman Docs |
Set up Cursor Rules, Claude.md, or Agents.md to give the agent context about your preferences, common doc structures, or naming conventions. Tip: You can add something like “Read this page <PageURL> first before answering any questions” and use your Superhuman Docs page to specify shortcuts, templates you like to use, prompt banks, and many other preferences. |
Ask for alternatives to confirm the approach |
Try saying "give me 3 different ways to organize this information" when you're not sure what structure you want. The agent can propose options for you to choose from. |
Customize your tool permissions to stop it asking you each time |
If you don’t want the agent to ask permission for every tool call in the MCP, you can choose to use an Allowlist or Run everything inside of Claude Code, Cursor, Codex, etc. |
Building your own agent
Let the agent choose tools to call, don’t name them in Code |
Don't call tools directly in your prompts. This is especially relevant if you are building your own custom agents with the MCP. There are two problems with calling tools directly:
Example use cases
Starter examples:
Transform bullets into polished writeup
Create and populate tables from scratch
Search and extract insights from data
- Provide a Superhuman doc URL to your AI tool
- Ask it questions about the data
Structure unorganized meeting notes
Intermediate examples:
Generate write-ups from your codebase
- Point AI to GitHub repo or local codebase
- Specify what to document (API endpoints, architecture, specific modules)
- AI analyzes code and generates structured write-up
- Content is written directly to the page of your doc with proper formatting, tables for API specs, and code examples
Create a weekly update summary
- Ask AI to read your table and filter to relevant updates
- Let it know how you want to format the message, how notes should be grouped, how blank values should be handled, etc.
- Once the method works, ask AI to create a reusable prompt for you and save it in a Superhuman doc for reuse!
Centralized feedback and comments review
- AI reads page with comments
- Extracts and categorizes all feedback
- Creates summary table with comment text, author, topic, priority
- Generates action items or response plan based on feedback themes
Advanced examples:
Batch content updates and migrations
- Define transformation rules (e.g., 'Update all status fields from old values to new taxonomy')
- AI reads current state using pagination
- Processes changes in batches to respect limits
- Updates content with new structure/values
- Provides summary of changes made
Build prompt libraries and instruction sets
- Create table structure for prompts (category, use case, prompt text, variables, example output)
- AI helps refine and categorize prompts
- Build library of tested, effective prompts
- Add “shortcuts” or rules into the table for when a prompt should get triggered
- Use Cursor Rules, Agent.MD, Claude.MD files to tell your agents to read the prompt library first and use those prompts when appropriate
💡 Ready to dive even deeper into the Superhuman Docs MCP? Check out these helpful guides:
I already connected to the Coda MCP before the Superhuman Docs launch - do I need to switch to the new Superhuman Docs MCP?
Does my role in Docs affect what I can do with the MCP?
Yes, your role does affect how you can use the Superhuman Docs MCP.
Can I limit what the MCP can change in my docs?
Yes. The MCP acts as you, so it can only do what your doc permissions allow, and page and table locking can add guardrails, such as asking for confirmation. To learn how doc permissions, locking, and admin settings work together, see Control what the Docs MCP can access. For limits you set when you connect, such as Limited access and read or write scope, see Security recommendations for the Docs MCP.
How does pricing work for the Superhuman Docs MCP?
What actions or tools does the MCP have access to?
You can find the full list of Superhuman Docs MCP tools and endpoints here.
The Coda MCP is sometimes returning coda.io URLs, even though I'm using Superhuman Docs - is that expected?
Yes, this is expected in some places for now. If you are still using the Coda MCP, it may sometimes share a coda.io URL. For instance, if you ask it to create a doc and give you the link, you may see a coda.io link. Redirects are handled automatically, so clicking the link should lead you to the correct docs.superhuman.com URL.
I gave my AI tool a docs.superhuman.com link, but it says it can't find the doc because it's not a Coda doc?
If you're still connected via the original Coda MCP, it's built to recognize coda.io-formatted URLs. Therefore, when you share a docs.superhuman.com link you in a prompt, your AI tool may incorrectly assume it cannot access the link. This is not a common issue, but if you do encounter it, we suggest adding custom instructions to your agent - such as "Use Coda MCP for both docs.superhuman.com and coda.io URLs."
How do I submit bugs or feedback for the MCP?
Please submit any bugs or feedback via this form. Thank you in advance!
