Access your Coda account settings, make updates to your preferences, and more.
Your Coda account is the individual account that you use to sign in and access Coda. Each Coda account is associated with a single user and a single email address. And you can use one account to access multiple workspaces.
Your Coda account settings house all of your account-specific information. This includes your email address, your notification preferences, your API settings, and more. Continue reading to learn all about account settings, including what info you can find and what actions you can take.
Access your account settings
You can access your Coda account settings in one of two ways:
While logged into Coda, click on your avatar and name in the lower-left corner of any page or doc, then select Account settings from the menu.
Tip: If you're in a doc and the page list is hidden, you just need to hover over the left edge of the doc to reveal the page list and your avatar.
Go to coda.io/account
That’s it - you are now in your Coda account settings. Take a look around!
Contents of account settings
Your account settings contain lots of information and options, split into sections. We’ll cover those sections - including some of the modifications you can make in each - below.
ℹ️ Note that if you are a user on an Enterprise plan, some account settings may be managed by your organization admin.
Profile picture, name, and email
At the top of your account settings, you’ll see your profile image, name, and email address.
To learn about your profile picture - including how to update it - check out this article.
To change your account name, simply click on the pencil icon next to your name. If clicking on this pencil icon doesn’t work, this is likely because your Coda account is linked to a Google account. In this case, you can change your name in one of two ways:
Change your name directly in your Google account, then sign back into your Coda account to have the update reflected there.
Alternatively, you can stop using Google as your login method, and switch to email/password login. First, add a password to your Coda account (in the Security settings section), then sign out and log back into Coda via email/password, instead of via Google. Once that’s done, go into your Google account settings and remove Coda. You’ll then be able to change your name directly in your Coda account settings.
There isn’t any way to directly change the email address associated with your Coda account, but in some cases if you use a third-party identity provider (e.g. Google) Coda will sync email changes as long as the same third-party account is used to log in. As an alternative workaround, you can create a new Coda account with your new email, and invite this new Coda account to your current workspace(s). Then you can transfer ownership of your docs from your old account to your new one.
Security settings
Here you will see security info related to your account, including password information (if you use email/password as your login method).
Publishing preferences
This section contains advanced settings related to publishing, including the option to enable Google Analytics pixel to track page views for your published docs (learn more about this here).
New document defaults
Set defaults for newly created docs, including page width, time zone, and first day of week. These preferences will apply to all docs you create going forward.
Billing info
This section shows all workspaces that your account is a member of, along with the tier of each workspace. If you’re a workspace admin, you’ll also have quick links to your workspace settings.
Email settings and preferences
Use this section to enable or unsubscribe from various types of emails and notifications, depending on your preferences. Learn more about email preferences here.
API settings
Here you can create a new API token and see a list of all existing API tokens associated with your account. Learn more about Coda API here.
Accounts connected to Packs
This section contains a full list of all Pack accounts that have been connected via this Coda account. You can even disconnect Pack accounts directly from this section.
Other integrations
See and manage any other integrations that might be connected to this Coda account, including Coda Bot for Slack.
Cookie settings
Here you can opt in or out of advertising and third-party publisher cookies. Learn more within your account settings.
Advanced settings
In the Advanced settings section, you’ll see two available actions:
How can I delete my Coda account?
Learn all about deleting your Coda account in this article.
Can I change the email address associated with my Coda account?
It isn’t possible to directly change the email address of an existing Coda account. As a workaround, you can create a new Coda account with the new email address. Then invite this new Coda account to your Coda workspace(s). Finally, transfer ownership of your docs to this new account. If needed, you can then delete the original Coda account.
How do I create an API token?
You can create an API token in your account settings. Just follow these steps:
Scroll down to the API settings section
Click on the Generate API token button
Give your token a name, and add restrictions if needed
Click Generate API token to confirm
Your new token will appear at the top of the list. Click the Copy token button to copy and use.
