Generate a HAR file for troubleshooting
Learn how to generate a HAR file to debug potential network issues while working in Docs.
Sometimes, network-specific problems can cause issues when accessing or using Superhuman Docs. To facilitate debugging and resolving Docs issues that might be related to your network, it can be helpful to generate HAR files and attach them to your support request.
HAR file basics
HAR, short for HTTP Archive, logs the interactions between your browser and websites. A HAR file keeps track of resources loaded by the browser along with timing information for each resource, and can be used to identify issues such as slow load times or page rendering problems.
Generate a HAR file
The steps below will walk you through how to generate a HAR file, depending on your browser type.
Chrome / Edge / Chromium-based browser
  1. Open a new tab
  2. Right-click your mouse and click Inspect
  3. Select the Network tab
    • If you do not see the Network tab, click the More tabs button
  4. Enable Preserve log
  5. Click the Clear network log button in the top left corner
  6. Make sure Record network log button is on
  7. Reproduce the issue you are experiencing in the current tab
    • If the page is loading very slowly, wait until the page is fully loaded
    • If the page is not loading at all, wait for at least 3 minutes before continuing
  8. Click the Export HAR button
  9. Save the HAR file
Firefox
  1. Open a new tab
  2. Right-click your mouse and click Inspect Element
  4. Reproduce the issue you are experiencing in the current tab
  5. Right-click anywhere in the File column and select Save All as HAR
  6. Save the HAR file
Safari
  1. Open a new tab
  2. From the Develop menu, select Show Web Inspector
    1. If you do not see Develop menu, go to Safari > Settings, select Advanced tab, and enable Show features for web developers
    1. If the page is loading very slowly, wait until the page is fully loaded
    2. If the page is not loading at all, wait for at least 3 minutes before continuing
  5. Click the Export button
