Now it’s time to practice searching for anything in seconds β€” whether it’s a message from last week or an attachment from years ago πŸ”Ž
⚑ Try It Now
  1. Hit Cmd+K (Mac) or Ctrl+K (Windows) β†’ Search or /.Β
  2. Type your query, then hit Enter to search across your inbox, labels, and folders.
πŸ’‘ Tip: Check out the Tips panel on the right! Combine any of those search operators using β€œOR” or β€œAND” to expand or narrow your search (For example, searching for β€œfrom:superhuman.com or has:attachment” will search for any messages sent from superhuman.com or any messages containing an attachment).
Ask AI (Business & Enterprise Plans)
Take searching to the next level with Superhuman AI ✨
Ask AI finds what you need without having to remember senders, guess keywords, or scan subject lines.Β
⚑ Try It Now (optional)
  1. You must first be on the Business or Enterprise plan. To upgrade your plan, visit superhuman.com/admin.
  2. Hit Cmd+K or Ctrl+K β†’ Ask AI or ? to get started.Β
  3. Type your question (example: "When is the next offsite?") to have Superhuman AI do the searching for you.Β
πŸ’‘ Tip: Ask AI can do more than just search β€” it can also draft messages for you, create events, analyze emails, answer product questions, and combine information from your inbox and the web. Learn more here.
In the final lesson, you’ll dive into the calendar essentials in Superhuman Mail πŸ‘‡
