Turn ideas into polished messages in seconds. Superhuman AI helps you draft clear, compelling emails that sound like you without the extra effort.
Write with AI
⚡Try It Now on Desktop
When drafting a message, hit Cmd+J (Mac) or Ctrl+J (Windows) to write with AI. Then, type a prompt and hit Enter to have Superhuman AI draft a message. The more context and keywords you include, the more specific the drafted message will be.
Write with AI can also edit your work! Just hit Cmd+J or Ctrl+J in the draft, then select one of the suggestions, or use the “Describe how to edit the text” field to add in specific instructions.
Personalize how Superhuman AI writes!
⚡Try It Now on Mobile
Tap the Write with AI icon (pencil with sparkles) above your keyboard to write with Superhuman AI.
Or, if you'd prefer to write with just your voice instead, tap the voice icon above the keyboard. Just say what you want the email to convey — no need for perfect sentences — and when you stop, Superhuman AI turns your words into a polished draft in your tone in seconds ✨
💡 Tip: Accepting the draft doesn’t send the message. You’ll always have a chance to review and edit before it goes out!
Instant Reply
Wake up to an inbox where your replies are already written!
This is best for when you want to respond quickly and efficiently to emails, especially in these situations:
  • Routine responses: For standard replies like acknowledgments or confirmations.
  • Time-sensitive situations: For when you're short on time.
  • Overcoming writer's block: For when you're unsure how to start a response.
We show three draft replies at the bottom of the latest message in a thread that you have received.
  1. Open a message with Instant Replies at the bottom of the message.
  2. Hit Tab to cycle and preview each response.
  3. To insert the reply, hit Enter (Reply All), R (Reply), or F (Forward), make any edits, then send it right off.
  1. Tap the response you'd like to use — a draft message will appear that you can edit.
  2. Once the message is ready, tap the send button to fire it off.
Great job! Next, you’ll discover how to stay effortlessly on top of conversations with Auto Drafts that ensure every follow-up is stress-free.
