The Go Enterprise License Agreement gives your organization access to Superhuman Go and Grammarly, with new capabilities and integrations added regularly. This article explains how Go Enterprise works, how you manage membership, and how you provision access to features and agents.
My settings
The My Settings section lets you manage your account’s personal information.
Profile
To update your personal information, click Edit in the upper-right corner. Because some settings are managed through your linked Grammarly account, you’re redirected to the Grammarly Profile page.
To update the name on your account:
  1. Click Update next to Name.
  2. Enter your First name and Last name.
  3. Click Update to save the changes.
To review the permissions for the role on your account, click View permissions next to Role.
To update the email address for your account or delete your account, contact the Customer Care team.
Admin settings
The Admin Settings section is available to admins only. Use it to manage your team subscription, members list, and roles across your suite of Superhuman apps.
General
To update your team name:
  1. On the General page, click Edit next to the team name.
  2. Enter the new name in the Team name field.
  3. Click Save name to update the team name across the apps.
Members
To invite team members to your subscription and give them access to Grammarly and Go:
  1. On the Members page, click + Members in the upper-right corner.
  2. Enter up to 10 email addresses at a time, pressing space, enter, or tab after each email.
  3. Click Invite.
The number of available seats appears above the list of current members and in the Invite members window.
To cancel a pending invitation, click the three dots next to the email address and click Cancel invite.
To remove a member from the subscription, click the three dots next to the member’s email address and click Remove user.
To update the role for an account:
  1. Click the three dots next to the account.
  2. Choose Edit user from the dropdown menu.
  3. Click Save to confirm your changes.
Groups
To create a group of members:
  1. On the Groups page, click + Create group in the upper-right corner.
  2. Enter the Group name.
  3. Check the boxes next to the members you want to add to the group.
  4. Click Create group.
You can also create groups with the CSV template:
  1. Click Create groups via CSV.
  2. Download the template and add your team members’ accounts to create one or more groups.
  3. Upload the completed template by clicking Upload.
  4. Click Create groups.
Note: If team members were already assigned to groups in a Grammarly-only subscription before joining the Go Enterprise plan, the list of groups is migrated and synchronized with the Superhuman Groups page once you join the Go Enterprise subscription. After that, manage member groups on the Groups page in Superhuman.
One member can belong to several groups. A team member must join the subscription before you can add them to a group.
To edit a group, click the arrow next to it. On the page that opens, click Delete group to delete the group, or click Edit group to add more team members.
To remove a team member from a group, click the three dots next to the member’s account and click Remove from Group.
Subscription
The Subscription page shows the total number of seats for your subscription and the number of vacant seats available to assign.
Apps
Manage Go
The Manage Go page lets you customize how the Go assistant works for your team. It includes these settings:
  • Web Search: Controls whether the Go assistant and agents can access the public web. You can turn it on or off for the entire organization.
  • Agent Sharing: Controls whether team members can publish agents internally. You can turn it on or off for the entire organization.
  • Superhuman Go: Enables or disables the Go assistant for your organization.
To enable the Go assistant for specific groups, select them from the list under Add Groups, then click Apply Groups.
Manage Grammarly
The Manage Grammarly page takes you to the Grammarly Home page, where you can adjust all the features, preferences, and associated tools for Grammarly.
Agents
The Agents page lets you configure and manage these agents:
  • Proofreader
  • Plagiarism Checker
  • Translate
  • Explain it
  • AI Detector
  • Paraphraser
  • Reader Reactions
  • Humanizer
  • Resume Builder
To open the details and configuration options for an agent, double-click its row.
In the Agent Access section, use the dropdown menu to assign access to All users, No users, or Custom. The Custom option lets you select the groups of members who can use the agent.
The Agent details section shows the domains an agent is connected to and the apps where it operates.
Connectors
The Connectors page lets you manage all available Superhuman connectors to external sources. The library keeps expanding, with new integrations added regularly.
Click a connector to open its controls for permissions and user access. In the Connector access section, set its availability to Everyone, No one, or Custom.
When you set Connector access to Custom, the Configurations section appears. To change an existing configuration, click Edit next to it. To create another configuration, click + Add Configuration under the existing one.
Configurations let you specify member access, read and write permissions, OAuth scopes, and more.
The Connector details section shows the domains a connector is linked to and the apps where it operates.
