Use labels in Superhuman Mail to quickly categorize or store important information without cluttering your inbox 🏷️
Note: How labels work depends on your account. In a Gmail account, labels are your Gmail labels. In an Outlook account, your Outlook categories appear as labels β€” you can apply, remove, and create them right from Superhuman, and changes sync back to Outlook automatically.
Accessing Labels
  • From the main inbox, hit the Left arrow key to see your labels.
  • Or, hit Cmd+K (Mac) or Ctrl+K (Windows) β†’ go to [label].
Mobile (Gmail accounts only)
  • From the main inbox, tap the menu icon in the top-left corner of the inbox to see your labels.
  • Or, when viewing a conversation, pull down from the top of the inbox to open Superhuman Command, then type go to [label].
Outlook labels are coming to Mobile soon.
Adding a Label
  1. Select the message you would like to label, then hit Cmd+K or Ctrl+K β†’ Label or L.
  2. Type the name of an existing label, or type a new name to create one.
The labeled message will stay in your inbox, with the label displayed next to the subject line.
In an Outlook account, a new label you create here becomes an Outlook category and syncs back to Outlook automatically. New labels created in Mail start with a neutral gray color.
  1. Tap the message you would like to label.
  2. Pull down from the top of the inbox to open Superhuman Command, then type Label.
  3. Tap the desired label, or tap βž• to create a new label.
This will label the message and keep it in your inbox.
Removing a Label (without Archiving)
  1. Select the message with the label you’d like to remove, then hit Cmd+K or Ctrl+K β†’ Label or L.
  2. Type the name of the label you’d like to remove.
This will remove the label and keep the message in your inbox. In an Outlook account, the category is removed in Outlook too.
  1. Tap the message with the label you’d like to remove.
  3. Tap the label you’d like to remove.
Removing a Label (and Archiving)
  1. Select the message with the label you’d like to remove.
  2. Hit Cmd+K or Ctrl+K β†’ Remove from Label or Shift+Y to remove a label and archive a message at the same time.
This will remove the label and archive the message into the Done folder. To access the Done folder, hit Cmd+K or Ctrl+K β†’ go to Done or G then E.
  2. Pull down from the top of the inbox to open Superhuman Command, then type Remove from Label.
This will remove the label and archive the message into the Done folder. To access the Done folder, pull down from the top of the inbox to open Superhuman Command, then type go to Done.
Moving a Message into a Label
  1. Select the message you would like to move from your inbox into a label.
  2. Hit Cmd+K or Ctrl+K β†’ Move or V.
  3. Type the name of an existing label, or type a new name to create one.
This will apply the label and move the message from your inbox into the label. This is equivalent to labeling a conversation and marking it Done at the same time.
Note: In an Outlook account, hitting Cmd+K or Ctrl+K β†’ Move or V shows folders only, and not labels. Because Outlook categories are tags rather than destinations, you can apply a label by hitting Cmd+K or Ctrl+K β†’ Label or L. To see everything in that label, hit Cmd+K or Ctrl+K β†’ go to [label].
  1. Tap the message you would like to move from your inbox into a label.
  2. Pull down from the top of the inbox to open Superhuman Command, then type Move.
Deleting Labels
Gmail accounts: To delete a label on Desktop or Mobile, hit Cmd+K or Ctrl+K β†’ Open Gmail to delete the label there. The change will sync back to Mail.
Outlook accounts: To delete a label, hit Cmd+K or Ctrl+K β†’ Open Outlook and delete the category there. The change will sync back to Mail.
Can I use labels in my Outlook account?
Yes. Your Outlook categories appear as labels in Mail, so you can apply, remove, and create them right from Superhuman. Hit Cmd+K or Ctrl+K β†’ Label or L on any message, then type the name of an existing category or a new one. Your changes sync back to Outlook automatically.
Why do my Outlook categories show up as labels?
We use β€œlabels” consistently across Mail, and your Outlook categories map directly to Mail labels. Nothing changes on the Outlook side β€” it’s just our naming, so everything feels consistent as you move around Mail.
Can I create a new category in Mail?
Yes. Hit Cmd+K or Ctrl+K β†’ Label or L and type the name of your new category. New categories created in Mail start with a neutral gray color, and they sync back to Outlook as categories.
Can I rename a category in Mail?
Not yet. To rename a category, hit Cmd+K or Ctrl+K β†’ Open Outlook and make the change there.
Why don’t my categories show up in the Move menu?
In Outlook, categories are tags rather than folders or destinations, so Cmd+K or Ctrl+K β†’ Move or V shows your folders only. To see everything in a category, hit Cmd+K or Ctrl+K β†’ go to [label].
Can I build a Split Inbox from a category?
Yes. Hit Cmd+K or Ctrl+K β†’ Search or / to start a search, then enter label:β€œcategory name”. Hit Cmd+K or Ctrl+K β†’ New Split Inbox and select New split from search, then name your Split Inbox. From then on, adding that label to a message will send it to your new Split Inbox.
Will categories show up on Mobile?
Not yet. Category labels display on Desktop and Web for now, and Mobile support is on our radar for a future update.
Why can’t I see all my folders?
We now show a cap of nine folders until you see a Show more option to expand the rest of your folders.
