Download the iOS or Android app, and learn how to navigate Mobile here.
How to access Superhuman Command from the inbox
Pull down from the top of the inbox, then swipe right to open Superhuman Command — like you're making an "L."
How to access Superhuman Command from the message view
a. Pull down from the top of the message you're viewing to open Superhuman Command and take action.
b. Or, do a two-finger tap on a particular message to open Superhuman Command and take specific action on the message in question.
How to search
Tap the 🔍 icon at the bottom of the screen.
Or, when viewing your inbox, pull down from the top of the screen to search.
How to refresh
Superhuman Mail is optimized to display your inbox up-to-date!
If you'd like to manually refresh just to be sure, pull down from the top of the inbox, then swipe left  — like you're making a backward "L."
How to access folders/labels
Tap the menu icon in the upper-left corner to see your folders/labels.
How to move between Splits
When viewing your inbox, tap a Split Inbox located at the bottom of the screen to swap your view.
If your list of Splits extends past the edge of the screen, you can swipe from right to left to cycle through them.
How to return from an open message back to the inbox
When viewing an open message on iOS, swipe from left to right to return to the inbox.
When viewing an open message on Android, tap the back button at the bottom of the screen.
How to reply to a prior message
Tap the "..." on the right side of the message or swipe the message to the left to Reply, Reply All, or Forward the message.
How to customize your inbox view
To choose how much detail appears in your inbox, tap the menu icon in the upper-left corner, then tap ⚙️ Settings → Appearance → Inbox Density.
