You can quickly print an email in Superhuman Mail πŸ–¨οΈ βœ¨
  1. Open the thread you would like to print.
  2. To expand all messages in a thread, hit Shift+O.
  3. Hit Cmd+P (Mac) or Ctrl+P (Windows).
  4. Click Print.
Mobile (iOS only)
  1. Tap on the thread you would like to print.
  2. Pull down from the top of your inbox to open Superhuman Command.
  3. Type Print.
How do I print a single email on Desktop?
There isn’t a way to print a single email in a thread on Desktop, however we recommend the following workaround for the time being:
  2. Hit Shift+O twice to collapse all messages in the thread.
  3. Then use N and P to navigate to the message you want to print.
  4. Hit O to expand that message, then hit Cmd+P or Ctrl+P to print with just that message open.
How do I save an email as a PDF?
Mac
  1. Hit Cmd+P.
  2. Select Save as PDF from the dropdown in the bottom left corner.
  3. Click Print.
Windows
  1. Hit Ctrl+P.
  2. Under Select Printer, select Microsoft Print to PDF.
  3. Click Print.
