Table of Contents
Use Snippets to save time and work more efficiently when sending repetitive messages. These reusable templates can be inserted while drafting to speed up your workflow and cut down on typing ⚡
Creating Snippets
You can make Snippets in a few ways:
  • Cmd+K (Mac) or Ctrl+K (Windows) → Create Snippet to start from scratch.
    • Private: Only you can see and use this Snippet.
    • Team: Shared with teammates using Superhuman so they can see and use it too.
  • Cmd+K or Ctrl+K → Create Snippet from Draft to make a Snippet from a message you're drafting.
  • Cmd+K or Ctrl+K → Create Snippet from Message to make a Snippet from a message you're reading.
Mobile
For now, Snippets can only be created on Desktop.
MCP Server
Ask your AI assistant to create or edit a Snippet for you, so you can save your go-to replies without opening Superhuman.
Adding variables and placeholders in Snippets
Variables
You can include variables in your Snippets to automatically fill in details, like a person’s first name. All available built-in variables will appear in the right sidebar when creating a Snippet.
Placeholders
You can also add placeholders by putting any phrase in curly brackets. Superhuman Mail will warn you to fill those in before sending your message!
For example, in the screenshot above, {company_name} and {decline_reason} are used as placeholders. If those phrases aren’t replaced when you send the email, Mail will display a warning 👇
Share a Snippet with your team
Tired of looping in the same people or copying the same message over and over? Click Share with team to share your Snippet. That way, no one has to start from scratch — and your messages stay consistent in language, tone, and style.
Once you share a Snippet, it’s added to the Team Snippets section with your name as the author. Teammates can use it anytime, so everyone can move faster.
Snippet use cases
Here are a few examples of Snippets you can create and use:
  • Greetings
  • Follow-up messages
  • Cold outreach
  • Booking links
  • Common attachments
  • Internal updates
  • Hiring workflows
💡 Tip: Check out this blog post to see even more examples of powerful, time-saving Snippets!
Using Snippets
  1. Hit Cmd+K or Ctrl+K → Use Snippet (or Cmd+; or Ctrl+;) to open and use a Snippet directly from your inbox. Or, hit ; to use Snippet Inline.
  2. Type the Snippet you'd like to use.
  3. Hit Enter to insert the Snippet into the draft.
Mobile
  1. Tap ➕ when composing a message.
  2. Tap Add Snippet, then tap the Snippet you'd like to use.
  3. Tap the Snippet you'd like to use.
Editing Snippets
  1. Hit Cmd+K or Ctrl+K → go to Snippets or G then ;
  2. Open the Snippet of your choice, then hit Edit in the bottom left corner to make changes.
  3. Hit Cmd+Enter or Ctrl+Enter to save your edits.
💡 Tip: Turn on Share with team to share a high-performing Snippet with teammates!
Snippets metrics
Quickly see how all your Snippets are performing, and use those insights to understand which messages work best with your audience — then refine your responses for even better results 📈
To see your Snippets Metrics, hit Cmd+K or Ctrl+K → go to Snippets or G then ;
The number of sends, the open and response rates, and the author of the Snippet, will display beside each Snippet.
  • Sends —  the number of times a Snippet has been used in a response.
  • Opened — the number of times a message containing the Snippet has been viewed.
  • Replied —  the total number of responses received for messages that include the Snippet.
  • Author —  the original creator of the Snippet.
💡 Tip: Learn how to use Snippets to help your team move faster together ⚡
FAQ
Can I transfer my Snippets from another account?
There isn't a way to transfer Snippets between different accounts at the moment. If this is a feature you'd like to see, let our team know by emailing hello@superhuman.com.
