The Auto Label Library allows you to quickly create new Auto Labels with a single click.
The library features over a dozen Auto Labels, including:
  • Messages that need your response.
  • Invoices, bills, and payment notices.
  • Messages about scheduling a meeting.
  • And more...
  1. Click Settings ⚙️ → Auto Label Library.
  2. Click the Auto Label(s) you'd like to enable.
Moving forward, new emails —  plus the last 14 days of emails —  that match the Auto Label definition will automatically receive the Auto Label.
To disable an Auto Label, click Settings → Auto Labels
Mobile (iOS only)
  1. Pull down from the top of your inbox, then swipe right — like you're making an "L" — to open Superhuman Command.
  2. Type Auto Label Library.
  3. Tap an Auto Label to enable it instantly.
All new messages, including the past 14 days of messages, that match the Auto Label definition will be assigned the Auto Label.
The Auto Label Library is not yet available on Android.
