With Instant Intro, you can respond to introductions blazingly fast ⚡
When someone introduces you to a new contact, hit Cmd+K (Mac) or Ctrl+K (Windows) → Instant Intro. Or, hit Cmd+Shift+i (Mac) or Ctrl+Shift+i (Windows).
This will thank the introducer and move them to Bcc. If it’s not quite right, you can hit it again.
To customize your Instant Intro message, hit Cmd+K or Ctrl+K → Instant Intro Settings.
💡 Tip: Include {first_name} in your Instant Intro Settings to automatically add the introducer's name!
Mobile (iOS only)
When being introduced in a thread, tap ➕ when composing a message, then tap Instant Intro.
To customize your Instant Intro message, pull down from the top of the inbox and swipe right — like you're making an "L" — then type Instant Intro Settings.
Is there a character limit?
There is no limit, however, we recommend keeping your intro short and sweet!
I prefer a multi-line Instant Intro.
Instant Intros are designed to be simple one-liners. For longer messages, try following up with a Snippet.
Can I create multiple Instant Intros?
There isn't a way to create multiple Instant Intros at the moment. If this is a key part of your workflow, let our team know by hitting Cmd+K or Ctrl+K → Feedback.
