Autocorrect automatically fixes mistakes as you type — from misspellings to missing punctuation and capitalization. With it enabled, you can write faster and more confidently, boosting your typing speed by up to 30–50%.
To turn on Autocorrect, click Settings ⚙️ → Autocorrect, then select the languages you need.
Superhuman Mail's Autocorrect feature currently supports Dutch, English, French, German, Italian, Norwegian, Polish, Portuguese (Brazil), Portuguese (Portugal), Spanish, Swedish.
Mobile
Autocorrect is only available on Desktop at the moment.
What languages does Autocorrect support?
At the moment, Autocorrect is available for Dutch, English, French, German, Italian, Norwegian, Polish, Portuguese (Brazil), Portuguese (Portugal), Spanish, Swedish.
Click Settings ⚙️ → Autocorrect to select the languages you need. Autocorrect performs the fastest if you only select the languages you plan to use.
Need another language? Hit Cmd+K (Mac) or Ctrl+K (Windows) → Contact Us to let us know!
How can I prevent Autocorrect from making incorrect suggestions in languages that aren't supported yet?
To reduce friction, we advise hitting Cmd+K or Ctrl+K → Disable Autocorrect to prevent those language errors.
Instead, you can use our AI functionality to correct any spelling or grammatical errors within your email draft. Just select your text, hit Cmd+J or Ctrl+J, then select Fix spelling and grammar from the dropdown menu.
Autocorrect keeps correcting a name/acronym that I don’t want corrected — what do I do?
If you’d like Autocorrect to learn a certain spelling, hit Cmd+Z or Ctrl+Z to undo the correction. Once the text is red underlined, click on the text, then select Learn "word" to add that spelling to your personal dictionary.
