Take full control of your time away by setting your Out of Office reply right from Superhuman Mail. It syncs directly with your Gmail or Outlook account, so your message is live everywhere with just a few clicks!
Set your OOO reply
  1. Hit Cmd+K (Mac) or Ctrl+K (Windows) → Out of Office Reply.
  2. Toggle your responder on.
  3. Set your start and end date.
  4. Write a subject and formatted message.
  5. Choose if it sends internally, externally, or both.
  6. Hit Save to enable your OOO message.
Your message will show up on your OOO days so others will know you're unplugging for a bit 🔌
💡 Tip: If you've already set up an OOO reply in Gmail or Outlook, we’ll import your existing message for easy editing.
OOO detection
Mail automatically detects upcoming OOO events in your calendar, and gives you a nudge to set your OOO reply.
Mail will spot:
  • OOO events from your Google, Outlook, or Superhuman Mail calendar.
  • If you have an OOO event coming up in the next 7 days (and it's at least 1 day long), Mail will prompt you to set up your OOO reply and even pre-fill your responder with calendar details!
Note that for now, setting your OOO reply is only available on Desktop.
Can I set an OOO message for only one account?
Yes, the responder is configured per account. You can enable it for your work account, and leave your personal account untouched!
Can I preview or test the OOO reply?
We recommend hitting Cmd+K or Ctrl+K → OOO to review your OOO reply. Replies are handled via Gmail or Outlook APIs.
Can I disable the nudges?
To stop future nudges, select Opt out in the modal.
