While Superhuman Mail doesn't have a direct integration with Todoist just yet, there is a way to use them together in the Chrome browser.
  • First, install the Superhuman Mail Chrome Extension here.
  • Then, install the Todoist Chrome Extension here.
Once both extensions are installed:
  • Go to chrome://extensions/shortcuts
  • Look for the Add to Todoist shortcut.
Then, in Mail, just hit Shift+Option+A to quickly turn any email into a Todoist task ✅
💡 Tip: You can also hit Cmd+K (Mac) or Ctrl+K (Windows) → Note to Self to send yourself a to-do.
