Google Advanced Protection (GAP)
Google Workspace Accounts
By default, Superhuman Mail isn’t compatible with Google Advanced Protection (GAP). However, we've found that it is possible for Superhuman Mail to coexist with GAP if the account is part of a Google Workspace and the Workspace Admin explicitly allows Superhuman Mail to have access.
Note that this is not yet possible for personal Gmail accounts.
If you have an account that is part of a Google Workspace (i.e., your work email), your Workspace Admin can adjust your Workspace settings to enable Superhuman:
How to adjust your Google Workspace settings
1. Go to admin.google.com.
2. Under Security click on API Controls.
3. Ensure that this box is not checked (the default is not checked):
4. Visit Manage Third-Party Access (here's a direct link to that page):
5. Click on Add App then from that dropdown click on OAuth App Name Or Client ID.
6. Type in 649336022844-5drlcmeo8tov7aabf8atnrbnsv3t1447.apps.googleusercontent.com then hit Search and select Superhuman
7. Check the client ID and click Select:
8. Select Trusted then click Configure.
9. Follow steps 5-8 again to configure our iOS app. This time use the client ID 649336022844-jlrmhbd93nmaigclvn6etjfnttrlh7v7.apps.googleusercontent.com for step 6.
10. Follow steps 5-8 again to configure our Android app. This time use the client ID 649336022844-grdoc08d9gq2ka8jaukdrq2p43mhcdg6.apps.googleusercontent.com for step 6.
As a heads up, you may need to use OAuth App Name or Client ID for the iOS app rather than selecting iOS.
Personal Gmail Accounts
GAP and Superhuman Mail are not compatible for personal Gmail accounts. However, many Superhuman Mail users do not require GAP for their personal accounts:
GAP does three things:
  1. Requires you to use a U2F 2-factor-auth device (like a Yubikey) instead of getting text messages or using an authenticator app.
  2. Prevents 3rd party clients (like Superhuman Mail or Apple Mail) from accessing Gmail or Google Drive.
  3. Prevents automated password recovery (to protect against the case where someone has access to your backup email address).
You can get the security advantages of #1 without sacrificing #2, by setting up two U2F devices in your Google Account's 2-factor-auth settings, and removing your phone as a 2-factor-auth device.
