With Grammarly support in Superhuman Mail, you can write and send emails faster than ever before. No more spending hours proofreading that important report or email ✨
Download Grammarly
Download the Grammarly desktop app by clicking the green Get Grammarly button.
Note: Superhuman Mail only supports the Grammarly Desktop app and Mobile apps. This is separate from the "Grammarly Editor" app and the Grammarly Chrome extension.
Mobile
Download the Grammarly app in the App Store for iOS or by visiting this page.
Once installed, follow the steps provided in the app. You'll also need to add the Grammarly Keyboard in order for it to appear in Superhuman Mail:
  1. Go to your Settings.
  2. Tap on Grammarly.
  3. Tap on Keyboards.
  4. Toggle on Grammarly.
  5. Toggle on Allow Full Access.
When composing a message in Superhuman Mail, press and hold the globe icon in the bottom left corner to prompt a keyboard menu. Choose Grammarly and you'll notice the green Grammarly icon appears when composing a message! ✨
Grammarly isn't working
Currently, the Grammarly Chrome extension will override the Grammarly Desktop app. This means that if you have both installed, you'll want to toggle off the Grammarly Chrome extension when using Superhuman Mail to allow the Grammarly Desktop app to work:
Once that's disabled, you'll notice the Grammarly icon appear when composing a message:
Grammarly on Mac Permissions
You may need to grant the Grammarly app permissions in your Mac's Security & Privacy settings under "Accessibility". Then, you can sign in to your Grammarly account through the app!
Why can't I use the Grammarly Chrome extension?
We unfortunately noticed a significant decrease in performance with the Grammarly Chrome extension enabled. We prioritized enabling the Grammarly Desktop app instead since there was no change in performance in Superhuman Mail when downloaded.
