Desktop Shortcuts
Move through your inbox twice as fast using Superhuman Mail shortcuts on Desktop ⚡
The first shortcut to remember is Cmd+K (Mac) or Ctrl+K (Windows). This opens Superhuman Command, your master control to find and take any action.
You'll see each action’s shortcut on the right, making it easy to learn as you go. Once you've memorized a shortcut, you can use it instantly from anywhere in your inbox — no need to open Superhuman Command.
You can also learn shortcuts by hovering over any button in Mail.
💡 Tip: No need to memorize every shortcut at once. Start with the actions you do most —  like C to compose or / to search your inbox —  and build from there!
Where can I see all Superhuman Mail shortcuts?
To see all shortcuts in Superhuman Mail, hit Cmd+K or Ctrl+K → Shortcuts. You can also download this PDF.
Can I customize the shortcuts?
There isn't a way to customize shortcuts in Mail at the moment, but if this is something you'd like to see, give our team a shout by clicking “Let us know” at the bottom of this help article.
A shortcut doesn't work on my keyboard.
A shortcut might not work if another one is already using the same key combination. Reference this guide for troubleshooting steps.
I'm using an international keyboard.
This guide shares tips on how to use Mail with an international keyboard.
