Split Inbox Library
The Split Inbox Library is the fastest way to personalize your inbox and the easiest way to onboard your team.
The library includes Split Inboxes based on roles and other categories, including:
  • Collaboration
  • Leadership
  • Sales
  • And more...
  1. Click Settings ⚙️ → Split Inbox Library.
  2. Click the Split(s) you'd like to add.
Mobile
  1. To open Superhuman Command, pull down from the top of your inbox, then swipe right — like you're making an "L.”
  2. Type Split Inbox Library.
  3. Tap a Split to enable it instantly.
I'm not seeing Split Inbox Library as an option.
Hit Cmd+K (Mac) or Ctrl+K (Windows) → Check for Updates to ensure you're running the latest version on Desktop.
