Schedule events directly from your inbox, either on your own or with Superhuman AI ✨
Superhuman AI
Schedule an event in seconds with Ask AI — it instantly finds a time that works for you and your team!
  2. Hit Cmd+K (Mac) or Ctrl+K (Windows) → Ask AI or ?
  3. Type your prompt with the time, invitees, and location, to have Superhuman AI create an event for you.
  4. Click Edit to modify the draft event.
  5. Hit Save to invite others, and add the event to your calendar.
Mobile
  1. Pull down from the top of the inbox, then swipe right for Superhuman Command — like you're making an "L."
  2. Type Ask AI.
Superhuman AI can also create events for you automatically from any open message.
  1. In an open message, hit Cmd+K or Ctrl+K → Create Event or B.
  2. Superhuman AI will automatically include recipients from the thread, a summary of the meeting’s purpose, default Meeting Link Settings, and suggest the best time based on your availability and your team’s!
Mobile
  1. In an open message, pull down from the top of the inbox, then type Create Event.
  2. Or, tap Create event if the suggestion appears at the bottom of the message.
💡 Tip: Learn how to personalize Superhuman AI when it creates events.
Create Empty Event
Create an event manually in the day or week view.
  1. Hit Cmd+K or Ctrl+K → open Day or 0 (zero) to see your day, or 2 to see your week.
  2. Select a time on your calendar.
  3. Hit Cmd+K or Ctrl+K to add more details, including a Zoom, Google Meet, or Microsoft Teams link, location, description, and more.
  4. Hit Save to invite others and add the event to your calendar.
You can also hit Cmd+K or Ctrl+K → Create Empty Event.
💡 Tip: Hit Cmd+K or Ctrl+K → Calendar Settings to customize your meeting link settings.
Mobile
  1. Tap the Calendar icon in the top left corner to open your calendar and create an event.
  2. Tap a time on your calendar.
  3. Once you’ve filled in the details, tap Save to invite others and add the event to your calendar.
You can also pull down from the top of the inbox, then swipe right for Superhuman Command — like you're making an "L” — and type Create Empty Event.
Edit Event
Easily edit or delete events in Superhuman Mail from the day or week view.
  1. Click the event you’d like to edit or delete.
  2. Click the three dots in the top right corner.
  3. Click Edit or Delete.
  4. When editing or deleting recurring events, choose whether you’d like to edit or delete Only this event, This and all following events, or All events.
Mobile
  1. Tap the event you’d like to edit or delete.
  2. Tap the pencil icon in the bottom right corner.
  3. Tap Save to save your changes.
Ready to uncover more calendar features? Learn how to share your availability, schedule with your team, and manage your calendars 📆
Can I change the color of an event?
At the moment, Mail will reflect the event colors set in Google Calendar or Outlook, but doesn’t directly support changing event colors. If this is something you’d like to see, let our team know by hitting Cmd+K or Ctrl+KFeedback.
I don’t see Edit Events in my account.
Hit Cmd+K or Ctrl+KCheck for Updates to ensure you’re on the latest version of the app.
Can I edit events if I’m not the owner?
No, you’ll only be able to edit events if you’re the owner or have full edit permissions on the calendar.
What happens if I edit an event while offline?
You can still make edits offline. If someone else edits the same event while you’re offline, the most recent version will be saved once you’re reconnected.
