Custom Split Inbox
TL;DR
Create Custom Split Inboxes to organize your inbox and prioritize important emails first.
  • Desktop: Click Settings ⚙️ → Split Inbox Library then click Build Your Own to create your own Split Inbox. To add to a Split Inbox, hit Cmd+K (Mac) or Ctrl+K (Windows) → Add to Split.
  • Mobile: Two-finger tap then type Split Inbox Library to build your own Split Inbox. To add to a Split Inbox, two-finger tap, then type Add to Split.
  • You can build Split Inboxes using Search criteria or Auto Labels.
  • To help you reach Inbox Zero, the total number of conversations appears beside each Split Inbox.
  • When setting up Split Inboxes, aim for no more than seven for optimal productivity.
Split Inboxes are intentional sections at the top of your inbox designed to enhance focus. They help you prioritize important emails and batch process similar messages.
To help you reach Inbox Zero, the total number of conversations appear beside each Split Inbox. If you've reached Inbox Zero in a Split Inbox or if the total exceeds 999, the count will not be displayed.
To navigate between Split Inboxes on Desktop, hit Tab to move right and Shift+Tab to move left. On Mobile, simply tap the Split Inbox name.
Create a Custom Split Inbox
In addition to default Split Inboxes, you can create a custom Split Inbox to better organize your inbox and stay focused.
You can create your own Split Inbox through the Split Inbox Library.
  1. Click Settings ⚙️  Split Inbox Library.
  2. Click Build Your Own.
  3. Enter the Name of your new Split Inbox.
  4. For the Split Inbox Definition, enter Search criteria like From:, To:, Subject:, Bcc:, Cc:. You can combine multiple criteria with the keywords OR and AND.
  5. Under Auto Labels, you can define Split Inboxes based on built-in or custom Auto Labels. You can use Auto Labels in addition to or instead of traditional Definitions.
  6. Hit Create to add your new Split Inbox to the top of your inbox.
💡 Tip: Name your Split Inboxes with an emoji to save space and add color! Just hit : then type the emoji name. For example, :clipboard = 📋
Mobile
  1. Pull down from the top of the inbox for Superhuman Command, then swipe right — like you're making an "L."
  2. Type Split Inbox Library
  3. Under Build your own, tap how you'd like to define your Split Inbox (Choose between the email address, domain, label, subject, or Auto Label).
  4. With the Auto Label criteria, you can define your Split Inbox based on built-in or custom Auto Labels
  5. Tap Split to add your new Split Inbox to the top of your inbox.
Edit Split Inbox
You can edit, disable, delete, or reorder your custom Split Inboxes.
To edit, disable, or delete a Split Inbox:
  1. Click Settings ⚙️ → Split Inbox.
    • To make edits, click ⚙️ next to the Split Inbox you've created to modify its contents.
    • To disable a Split Inbox, uncheck the box beside it.
    • To delete a custom Split Inbox, select Delete Split Inbox.
  2. When a Split Inbox is turned off or deleted, conversations from that Split Inbox will move back to Important or Other.
To reorder your Split Inboxes, click and drag the hamburger icon (three horizontal lines).
💡 Tip: To see conversations in both their Split Inbox and Important/Other, click ⚙️ next to the Split Inbox, and check the box beside Also show conversations that match this Split Inbox in Important or Other.
Mobile
  2. Type Split Inbox Settings.
  3. Tap the account where you want to make edits.
  4. Tap the Split Inbox you'd like to edit.
    • To disable a Split, toggle off Show Split Inbox
    • To delete a Split you've made, tap Delete Split Inbox.
  5. When a Split Inbox is turned off or deleted, conversations from that Split Inbox will move back to Important or Other.
Add to Split Inbox
You can add multiple criteria to a custom Split Inbox.
  1. Select the conversation you would like to add to an existing Split Inbox.
  2. Hit Cmd+K or Ctrl+KAdd to Split Inbox.
  3. Use the Up and Down arrow keys to select a definition. (Choose between the full email address, domain, recipient, subject, label, or Auto Label).
  4. Hit Enter on your selection, then select which Split Inbox you'd like to add to.
Those emails will now be sorted into the Split Inbox you chose!
Mobile
  1. Tap the message you would like to add to a Split Inbox.
  2. Pull down from the top of the inbox, then type Add to Split Inbox.
  3. Select whether you'd like to add the full email address or the domain.
  4. Tap the Split Inbox you'd like to add to.
I want my messages to appear in its Split Inbox and Important/Other.
To have messages duplicate in Important/Other, click Settings ⚙️ → Split Inbox then click ⚙️ next to the Split Inbox. Check the box beside Also show conversations that match this Split Inbox in Important or Other.
How many Split Inboxes can I create?
Though there isn't a limit to how many Split Inboxes you can create, we recommend no more than seven for optimal productivity. Having more than that can slow you down as it creates more places to check.
Can I create a Split Inbox based on keywords?
There isn't a way to create a Split Inbox based on keywords in the body; however, if you have a Gmail account, you can set up a filter to label these emails, then create a Split Inbox based on this label.
  1. Hit Cmd+K or Ctrl+K → Open Filter Settings.
  2. At the bottom, click Create Filter.
  3. In the has the words: field, enter the keywords.
  4. Click Create Filter.
  5. Check the box next to Apply the Label and create a label.
  6. Click Create Filter
Then, in Superhuman Mail:
  1. Hit to start a Search.
  2. Type in label:label name and hit Enter
  3. Hit Cmd+K or Ctrl+K → Split Inbox and name your Split Inbox.
Are Split Inboxes like folders?
No. Split Inboxes should contain emails that still require action. Folders, on the other hand, are best for storing messages you’ve already actioned.
Can my Split Inboxes reflect the unread count instead of the total count?
There isn't a way to change the total count to show unread only, however, you can filter unread conversations by hitting Cmd+K or Ctrl+K → Filter Conversations
