Dealing with Unwanted Emails
Spam and junk mail clog your inbox and lower your focus. With Superhuman Mail, you can delete, unsubscribe, block, or mark a message as Spam in an instant!
Delete
To delete a message, hit Cmd+K (Mac) or Ctrl+K (Windows) → Delete.
Mobile
To delete a message on Mobile:
  1. Tap the message open.
  2. Pull down from the top of the inbox for Superhuman Command.
  3. Type Delete.
Unsubscribe
To unsubscribe, hit Cmd+U or Ctrl+U.
Several options will appear:
  • Unsubscribe — unsubscribes you from the newsletter.
  • Unsubscribe, and Mark Done all — unsubscribes you from the newsletter, and archives all existing newsletters in the inbox.
  • Unsubscribe, and Trash all —  unsubscribes you from the newsletter, and trashes all existing newsletters in the inbox.
Mobile
To unsubscribe on Mobile:
  3. Tap Unsubscribe then several options will appear:
Block
For emails that do not have an unsubscribe link, you can block them instead by hitting Cmd+K or Ctrl+K → Block. You can block the sender or domain from landing in your inbox.
Mobile
To block emails on Mobile:
  3. Type Block to block the sender or domain.
Spam
Hit Cmd+K or Ctrl+K → Mark Spam or ! to mark a message as Spam.
  • Mark Spam — marks the message as Spam and sends it to the Spam folder.
  • Mark Spam, and block full email address — marks the message as Spam, and blocks all messages from the full email address.
  • Mark Spam, and block domain —  marks the message as Spam, and blocks all messages from the domain.
Mobile
To mark a message as Spam on Mobile:
  3. Type Mark Spam
Does Superhuman Mail automatically Unsubscribe for me?
Yes and no. Superhuman Mail takes one of three actions when you use the unsubscribe feature:
  • It sends an email to the source to unsubscribe for you.
  • It sends and email to the source to unsubscribe for you and pulls forward a company page.
  • It directs you to the unsubscribe page of the company.
Generally, Superhuman Mail can unsubscribe for you, unless a company has a particular Unsubscribe page.
If I Block a sender or domain, can I Unblock them?
Yes. On Desktop, hit Cmd+K or Ctrl+K → Blocked Senders to view the list of Blocked senders. You can Unblock an address simply by clicking Unblock. On Mobile, two-finger tap then type Blocked Senders. Select the account of your choice, then tap the red minus sign to Unblock an address.
Do you suggest marking emails as Junk rather than Unsubscribe or Block?
Junk and Block have similar results, but slightly different purposes.
Marking an email as Junk moves it to your Junk folder, but you aren't automatically blocking the sender. This should reroute any future emails from that sender to your Spam folder, but you may still receive some emails from the same domain in the future. Marking Junk helps train the system to identify similar types of emails and improve your inbox performance.
Blocking may be a better option when you want to stop receiving messages from an unwanted sender. These emails may not typically be Spam/Junk. Marking them as Junk would confuse the junk filter capturing unintended emails into the Junk folder. Blocking allows you to stop receiving those messages without confusing the Junk filter.
How do I empty my trash bin?
At the moment, there isn’t a way to empty the Trash directly in Mail. For now, you would need to empty the Trash in Gmail or Outlook.
