Mobile Navigation
Download the iOS or Android app, and learn how to navigate Mobile here
How to access Superhuman Command from the inbox
Pull down from the top of the inbox, then swipe right to open Superhuman Command — like you're making an "L."
How to access Superhuman Command from the message view
a. Pull down from the top of the message you're viewing to open Superhuman Command and take action.
b. Or, do a two-finger tap on a particular message to open Superhuman Command and take specific action on the message in question.
How to search
When viewing your inbox, pull down from the top of the screen to search.
How to refresh
Superhuman Mail is optimized to display your inbox up-to-date!
If you'd like to manually refresh just to be sure, pull down from the top of the inbox, then swipe left  — like you're making a backward "L."
How to access folders/labels
Pull up from the bottom of the screen when viewing your inbox, or tap Important or Inbox at the bottom of the screen.
How to move between Splits
When viewing your inbox, tap a Split located at the bottom of the screen to swap your view.
If your list of Splits extends past the edge of the screen, you can swipe from right to left to cycle through them.
How to return from an open message back to the inbox
When viewing an open message on iOS, swipe from left to right to return to the inbox.
When viewing an open message on Android, tap the back button at the bottom of the screen.
How to move to the next email from the message view (iOS only)
If you'd like to keep an email in your inbox and move on to the next, you can swipe the triage bar all the way from right to left to advance to the next message.
How to return to the previous email from the message view (iOS only)
If you'd like to return to the previous email, you can tap on the left-facing arrow located on the right side of the triage bar.
How to reply to a prior message
To action an earlier message in a thread:
  1. Open a thread on our Mobile app.
  2. Swipe left on the message you want to respond to.
  3. Choose one of the options from the menu that appears:
