Share drafts with teammates to collaborate more efficiently and perfect your messaging! ⚡
  1. Hit Cmd+K (Mac) or Ctrl+K (Windows) → Share draft or toggle on Share draft at the bottom of a message.
  2. Select who you’d like to share the draft and conversation with, then hit Share to start sharing.
  3. You can also hit Cmd+S or Ctrl+S to copy the link share. Once the link has been copied, you can paste it directly in Slack or Microsoft Teams. Anyone with the link will be able to see drafts, all past messages, and add comments.
Teammates on the conversation can now see the entire thread and the draft as it updates in real-time! They can leave comments to collaborate on the draft.
When you share a draft with teammates, a “Draft” label will appear in their threadlist.
To unshare a draft, hit Cmd+K or Ctrl+K → Unshare Draft or toggle off Share Draft at the bottom of the message.
Mobile
  1. Tap Share draft to begin sharing a draft.
  2. Select who you'd like to share the draft with, then tap Share to start sharing.
  3. You can also tap Copy to copy the link share, and paste it directly in Slack or Microsoft Teams.
Once a draft is shared, teammates in the conversation can see the full thread and watch the draft update in real time. They can also leave comments to collaborate directly on the draft 📝
Can anyone on a shared conversation make edits to the shared draft?
Only the original draft author can make edits to the draft at the moment.
Can I share just the draft?
Sharing a reply draft in a thread shares the entire thread like regular sharing (Cmd+K or Ctrl+K → Share Conversation). You can share a standalone draft, however if they’re unshared, that draft and its comments are no longer accessible to shared participants.
What notifications will participants receive when a draft is shared with them?
When a draft is first shared, teammates on a conversation will receive a push notification and a thread bump.
