Unified Inbox
While Superhuman Mail doesn't have a Unified Inbox feature, we can offer a workaround using tabs in our Native Apps to keep an eye on all of your inboxes, and quickly switch between them.
Workaround
To use this workaround, you'll want to first download our Native Mac or Windows app from here
First, you'll want to create tabs for each of your accounts like so:
  1. Hit Cmd+T (Mac) or Ctrl+T (Windows) to open a new tab.
  2. Hit Cmd+K or Ctrl+K → Switch Account.
Once you have all your tabs set up, you can switch between them like so:
  1. Hit Cmd+Shift+] or Ctrl+Shift+] to go to the next tab.
  2. Hit Cmd+Shift+[ or Ctrl+Shift+[ to go to the previous tab.
Alternatively, you can swap between these tabs using Cmd+1/2/3/etc. or Ctrl+1/2/3/etc. as you would with a browser.
Accidentally close a tab?
Sometimes shortcuts get the best of us and we accidentally close a tab!
You can recreate that tab by hitting Cmd+T or Ctrl+T then hit Cmd+K or Ctrl+K → Switch Accounts to change which account is open in that tab.
Renaming tabs
Right now, the content shown in the tab should appear with the name of your Split, followed by the count of that Split, and your account name — like shown below👇
There isn't a way to rename tabs for now, but please let us know if that's something you'd like to make possible!
