Structure Your Inbox
Now that you’re familiar with Superhuman Command and the interface, let’s dive into Split Inbox.
If you want to learn more about custom Split Inboxes, check out our Organize Your Inbox with Superhuman Mail guide.
Moving Conversations Between Important • Other
You can easily customize which messages land in Important or Other to make sure messages go to the right spot.
⚡ Try It Now (optional)
  1. Select the message currently in Other that you’d like to move to Important.
  2. Hit Cmd+K (Mac) or Ctrl+K (Windows) → Move to Important.
  3. Choose whether you’d like to move the single message, the sender, or the domain.
💡 Tip: Gmail users, make sure smart features are enabled in your Gmail settings by checking the box next to "Turn on smart features and personalization." This allows Superhuman Mail to properly sort your emails into Important and Other.
Split Navigation
To help you treat your inbox like a to-do list and work toward Inbox Zero, each Split Inbox shows the total number of messages — not just unread. You’ll learn more about why this works in the next article 😉
To navigate between Split Inboxes, hit Tab to move right and Shift+Tab to move left.
To reorder them, click Settings ⚙️ → Split Inbox then click and drag the hamburger icon (three horizontal lines).
💡 Tip: The ideal number of Split Inboxes is usually between three and seven. This keeps you productive without creating too many places to check or process messages.
Nice work setting up your inbox! Next, you’ll learn how to manage your inbox efficiently to keep email volume in check.
